Brief Description: Sand Micro on Targa Stip; Cut Trailing Edge
I sanded the micro along the leading edge of the targa strip flush with the electrical tape and then carefully removed the tape. This line turned out perfect! A very nice straight edge that follows the contour of the rollbar perfectly.Once I had the leading edge done, I had Adam help me remove the canopy. I then measured and marked where I wanted the trailing edge using the leading edge as a guide to make sure both edges were parallel. The big cut was then made using a cutoff wheel in my dremel tool. A little sanding with a long board-sander and I had a perfect trailing edge as well.Adam then helped me reinstall the canopy and you can see from these pictures how well everything turned out.
