Brief Description: Remove Peel Ply and Begin Sanding
Later that night we went back out to the garage to check on how the fiberglass was doing. It was pretty much dry. We peeled off the peel ply and it looks great! There really isn't much sanding needed at this point since the peel ply leaves just enough texture for the micro that will be applied next. The transition is getting smoother and smoother with each step!
