Dan's Web Site
Date:  8-1-2006
Brief Description:  Sand the Flox Filler - Ready for Fiberglass
Did I mention that Flox is not very easy to sand? My fingertips are raw sanding this stuff with 40 grit! Matt made quick work of the heavy areas with a sanding drum in the dremel tool but most of the work had to be done by hand. This will provide a nice base for the fiberglass. The Flox covered all of the aluminum clips and tabs nicely.
Left side of canopy sanded
Matt sanding the right side with the dremel tool
Canopy ready for fiberglass
