Brief Description: Final Trimming of Aft Edge of Tip Up Plexiglass
I heated up the basement again today and finished all of the remaining plexiglass work. Woohoo!I notched the lower aft corners to provide clearance from the aft skin. I also went through a couple of final iterations of shaving the aft edge and fitting the canopy to the frame to see how well the aft edge aligned with the reference line on the rollbar. It's finally perfect! Once I had the aft edge trimmed, I removed the canopy and did some final shaving/deburring of the front and side edges. All of the plexiglass drilling, countersinking, trimming, shaving, and deburring is complete!
Lower aft corners notched
Aft edge trimmed
Aft edge perfectly matched to rollbar reference line
