Brief Description: Drill/Bolt Attach Angles to F705 Bulkhea
I spent way too much time positioning the canopy frame attach angles on the F705 bulkhead and drilling the 1/4 inch holes for the AN4 bolts. The bolts do not have the nuts on them at this point. It looks like I may have a problem getting a wrench on the nuts and torquing them down given how close the two holes are to each other on each bracket.
Left attach angles drilled and bolted to F705 bulkhead
Right attach angles drilled and bolted to F705 bulkhead
