Brief Description: Taper Attach Angles to Fuselage Contour
I used a vixen file to taper the outboard face of the two canopy attach bracets (angles) to match the contour of the fuselage skins. I then polished the brackets on the scotchbrite wheel. I also had to trim the seat back adjustment plates on the top of the F705 bulkhead to allow clearance for the canopy attach brackets.
Outboard face of left attach angles tapered to fuselage contour
Outboard face of right attach angles tapered to fuselage contour
Seat back adjustment plate trimmed for canopy attach angles
