Brief Description: Sand Rage Along Front Corners & Targa Strip
Next I sanded the blue Rage filler on the canopy frame, specifically along the targa strip and on the front corners. With all of the compound curves and all of the various colors of micro, rage, fiberglass, and aluminum, it is difficult to tell if I have all of the highs/lows sanded out. No way to know for sure without priming!Once all of the sanding was done I vaccumed and cleaned everything with Acetone. I then applied the Wonder-fil pinhole filler and will let this dry overnight before wiping off the excess and priming. The Wonder-fil actually dries very fast but I'm out of time for today anyway so I'll let it sit overnight.
Rage sanded along targa strip
Rage sanded on front corners; pinholes filled with Wonderfil
