Brief Description: Final Drill Right C-613, WD-716, WD-725, C-723
After I made the C-723 wedges I pushed one into the gap between the flange of the C-613 splice plate and that of the WD-716 frame rail and then match-drilled everything to #30. I also drilled the upper tab of the WD-716 to the top of the WD-725 side rail. You're actually supposed to drill the two holes in this tab later after making some final adjustment of the frame to the plexiglass. I decided to drilll these holes now given that it's much easier to do this on the bench and given that the splice plate does not allow for any flexing at this joint.
Outside view of right WD-716 and WD-725 side rails drilled to C-613 splice plate
Inside view of right WD-716 and WD-725 side rails drilled to C-613 splice plate and C-723 wedge
