I started today by fabricating the two C-723 wedges (shims) that are needed to fill the gap between the bottom flange of the C-613 splice plate and the WD-716 canopy frame side rails. These were challenging to make due to their small size. I made the initial cuts using the bandsaw, then files, and then polished them up on the scotchbrite wheel.
