Brief Description: Notch Latch Support Angles for Ball Handle
Once the canopy latch support angles were drilled I temporarily assemble the latch mechanism and marked where the angles had to be notched for the yellow ball that will be used as the handle on the inside of the cabin. The angles were then notched and deburred.
Canopy latch temporarily together - bolts with no nuts
