Dan's Web Site
Date:  5-17-2008
Number of Hours:  1.50
Brief Description:  Add External Springs to Master Cylinders
Another task I've been meaning to get to has been to add external springs to each of the master cylinders to also help prevent the brakes from sticking. I'm not sure if these are necessary but once again several others on the RV-List have done this and recommend adding them.
I bought the springs and collars from McMaster. I used UHMV collars on the bottom and metal collars with allen screws on top to secure the springs under slight compression.
The brake pedals spring back nicely now with the single hinge point and added spring pressure.
Passenger side brake pedals with external springs installed on master cylinders
Pilot side brake pedals with external springs installed on master cylinders
