Brief Description: Replace Brake Pedal Bolts with Single AN3-56 Bolts
I thought I would tie up some loose ends before continuing on with the baffles. To that end I replaced the 2 short bolts securing each brake pedal with a single long AN3-56 bolt. This should make for a better hinge point for each pedal and allow the springs in the master cylinders to overcome the lower friction. There were several people on the RV-List that had very good results with this in preventing their brakes from sticking.
Left brake pedals now secured with single AN3-56 bolts
Right brake pedals now secured with single AN3-56 bolts
