Brief Description: Rivet Center Support Bracket; Bolt Pedal
I noticed that I hadn't dimpled the firewall for the F643B attach angle or for the panel/subpanel ribs. I dimpled these holes with the pop-rivet dimple dies. The next thing I worked on was the rudder/brake pedals. I decided it was about time to rivet the F6118 center support bracket to the firewall. I had to trim some off the firewall end of the bracket since I realized that this bracket rivets to the outboard side of the firewall angle and I had initially fitted this to the inboard side of the angle. Once the center support bracket was riveted, I bolted the rudder/brake pedal assembly to the auxillary longerons and center section.
Firewall dimpled for ribs
F6118 center support riveted to firewall; pedals bolted
