Brief Description: Install Aluminum Brake Lines in Cabin
I was dreading running the remaining brake lines in the cabin. The lines from the parking brake valve to the bulkhead fittings at each gear leg need to be high-pressure lines and Van's specifies 1/4" aluminum tubing. It didn't turn out to be too bad after all since the 1/4" tubing is relatively flexible, especially compared with the 3/8" fuel lines that were very difficult to work with. Anyway, all of the interior brake lines are complete!
Aluminum brake lines installed from parking brake valve to gear leg bulkhead fittings
