Dan's Web Site
Date:  1-16-2008
Number of Hours:  1.00
Brief Description:  Install New Avery Axle Nuts
Today I replaced the axle nuts on the main gear legs with new Avery axle nuts designed to work with their jack stand. The cotter pins have been installed along with the steel cover straps that will be used to help secure the wheel pants. Jacking up each gear leg whenever I need to do maintenance should be a piece of cake now.
Avery axle nut installed on left wheel
Avery axle nut installed on right whee
