Brief Description: Drill Rear Baggage Wall to F706
Once the shoulder harness cable wear blocks were done I clecoed the bottom portion of the rear baggage wall to the rear flanges of the baggage floor panels. I then used the holes in the wall panel to drill the F706 bulkhead. Once the bottom section was done, I clecoed the top section to the bottom section and then used the holes that I pre-drilled in the top section as a guide to drill the F706 bulkhead.
Rear baggage wall drilled and clecoed to F706 bulkhead
