Brief Description: Rudder/Brake Pedals:Drill Center Support
The next thing that I did was trim the center support bracket so it would fit around the firewall recess cover. The bracket was then positioned and drilled to the firewall angle. The final thing to do was to drill the various holes in the center support bracket to match the position holes that were drilled in the side skin stiffener angles. I just bolted the rudder pedal assembly into each position, clamped the center support block to the bracket and then match drilled the bracket using the holes in the block.
Center support bracket drilled and clecoed to firewall
Center support block clamped and ready to be drilled
