Brief Description: Drill Longerons to Upper Steel Brackets
The final drilling that I did today was the upper steel corner brackets to the longeron and side skins. I made sure everything was securely clamped together and then did the final drilling.
Outside view of side skin and longeron drilled to steel brackets
Inside view of side skin and longeron drilled to steel brackets
