My replacement seat belt bracket and F605C bars arrived from Van's today. I spent this evening tapering the F605C bars, clamping them to the long bar that reinforces the bottom of the F705 bulkhead channel, and match drilling them. I also clamped and drilled the one last seat belt bracket to these reinforcement bars that will be used to bolt the rear wing spars to. The final thing that I did tonight was grind down the bases of the outer seatbelt brackets to provide room for the floor ribs to be riveted to the base of this bulkhead.
F605C bars fabricated again - final seat belt bracket clamped
Bottom of F705 bulkhead drilled and ready to be primed
Outer seatbelt brackets - flanges ground down for ribs
