The F711 bulkhead is a double bulkhead. Both pieces had to have a large notch cut out of the tops for the elevator pushrod. I used the bandsaw to make these cuts and then the dremel to clean them up. Then I cut the 2 bars that will be used to attach the horizontal stabilizer. These bars are not prepunched so I drew a centerline on each bar that I can use to center the bars over the prepunched holes in the bulkheads. I'll drill these out tomorrow.
Cut bars and bulkheads for horizontal stabilizer attach
