Brief Description: Center Section: Rivet Bulkheads
I used the wing attach bolts again to properly align the side sections on each end of the forward and aft center section bulkheads. Once everything was aligned, I put clecoes in all of the rivet holes to hold everything securely. I then used the pneumatic squeezer to set as many rivets as could be reached with the longeron yoke. Then I broke out the rivet gun and bucking bars to set the rest of the rivets for the side sections. Once the veritcal side sections were riveted to each end of the forward and aft center section bulkheads I bolted and screwed on the cover brackets and control column mounting brackets. All of the bolts were properly torqued. This completes the Center Section bulkeads.
