Brief Description: Aileron Trim:Fabricate Control Mechanism
After everything was drilled I removed the mounting plate and polished the edges, drilled the holes for the nutplates, deburred everything, and riveted the nutplates to the plate. The swivel arm was then inserted into the plastic block and secured with a large washer and cotter pin. The assembly was then screwed to the mounting plate.
Nutplates installed on mounting plate and swivel arm installed
Swivel block and arm mounted to plate - bottom view
