Brief Description: Prime Pipes/Skins; Rivet Forward Skeleto
I put another coat of primer on the counterbalance pipes - this time the Sherwin Williams 988 primer. I then primed the insides of the forward skins. Once everything was dry, I riveted the reinforcement plates to each end of the spars. I then riveted the nose ribs to the reinforcement plates and spars. The counterbalance pipes were then blinde riveted to the nose rib tabs.
