Dan's Web Site
Date:  10-12-2002
Number of Hours:  2.50
Brief Description:  Rivet Left Main Ribs to Rear Spar
I thought riveting on the rear spar was going to be easy. I used the pneumatic squeezer. However, after I had set all of the rivets, I went back and closely examined all of the rivets. There were several that had split up the middle. I drilled these out and discovered the problem. The rivets that I was using were too long. So much for trusting the plans. I need to remember to double check all of the rivet lengths with the rivet gauge. When I used the slightly shorter rivets, no splits...The next step will be to mount this structure into the wing jig.
Left main ribs riveted to front and rear spars
Left rear spar riveted to main ribs
