Dan's Web Site
RV-7A
Left Wing
3-16-2012
Install Tip on Wing; Drill Rib to Tip
Next I clecoed the left wing tip to the wing and then used side grip clecoes to hold the wing tip rib in place while drilling for all the rivet holes.
Fiberglass wing tip clecoed to wing with the rib clamped in place using side grip clecoes
Top holes drilled and rib clecoed to wing tip
Bottom holes drilled and rib clecoed to wing tip
RV-7A Home
2363
Ailerons
Assembly
Baffles
134
110
Big Dig
Brakes
Canopy Frame
144
152
Cowl
68
74
Electrial
120
96
96
Elevator
Filtered Air Box
Flaps
Forward Fuselage
460
Gear
Hangar
Hardware
Horizontal Stabilizer
Left Aileron
Left Flap
Left Fuel Tank
Left Wing
90
117
Panel
Photo Shoot
25
Right Aileron
Right Flap
Right Fuel Tank
43
60
Right Wing
84
Rudder II
Seats
Service Bulletin: No
Spinner
Systems
Training
Vertical Stabilizer
146
