I used the same wood blocks that were used to bend the elevator cutout tabs to bend the small end tabs in the trim tab. The bends were pretty challenging since they are so small. I used double-edged tape to prevent the blocks from slipping around on the skin. Pulling this tape off proved to be a challenge. When everything was finally all said and done, my first edge actually turned out pretty good - nice and straight!
