Brief Description: Replaced Platenuts with Dimpled Platenut
I ended up drilling out all of the rivets holding the incorrect platenuts on and then riveting on the dimpled platenuts. This took some time but went fairly smooth. I really didn't bugger up any of the holes - the rivet removal tool from Avery's worked great!
Here is the bottom view of the correct platenuts riveted in place
Here is an inside view of the correct platenuts riveted in place
