Brief Description: Vertical Stabilizer Clecoed Together
I spent tonight straightening the Vertical Stabilizer ribs with the fluting pliers and finishing the edges on the Scotchbrite wheel. Once this was done, the ribs were clecoed to the spars and final drilled. Then the skin was clecoed to the skeleton and after everything was ligned up, all of the appropriate holes were drilled in the rear spar. The skin is now ready to be drilled to the skeleton!
