Dan's Web Site
Date:  11-12-2006
Number of Hours:  1.50
Brief Description:  Sand / Clean / Micro Vert Stabilizer Tip
OK, back to the fiberglass work...Next I sanded the previous iteration of micro on the vertical stabilzer tip. It still needed to be built up a bit to match the shape of the rudder tip so I cleaned everything with Acetone again and frosted another layer of micro over the tip. The vertical stabilizer tip was so tall and flimsy that it had bowed inward and needed to be built back up with filler.
Vertical stabilizer tip sanded, cleaned, and microed again
