It was rather difficult clecoing the skin over the left side skeleton. As more and more cleco's were added, the holes lined up better and better until everything came into alignment. Also, it was hard getting the cleco's into the prepunched holes. They are undersized just enough to require some wiggling and jiggling of the cleco's to get them in. The few holes that I did need to measure and drill like the intersection of the HS-404, 405 Ribs with the HS-702, 710, and 714 front spar turned out pretty good. Everything once again lined up fine.
Left Horizontal Stabilzer Clecoed Together Ready to be Drilled.
HS-404 and HS-405 Ribs Clamped into Place.
HS-404, 405 Ribs, HS-702, 710, & 714 Front Spar Drilled/Clecoed
