Dan's Web Site
Date:  5-1-2005
Number of Hours:  1.00
Brief Description:  Set Incidence: Left Wing
Once the right wing was set and clamped it was on to the left wing. I used the Van's recommended makeshift gizmo to adjust the rear spar such that the left wing incidence was set where it needed to be. I checked both the inboard and outboard sections of the wing and they were the same,,,once again, no twist! Yeah! I then double checked that the plumb bobs were still aligned before clamping the rear spar to the fuselage F705 bars. Finally, it's time to drill the rear spars!
Left inboard wing incidence perfect
Left outboard wing incidence perfect - zero twist
