Dan's Web Site
Date:  4-30-2005
Number of Hours:  1.00
Brief Description:  Right: Mate / Bolt to Fuselage
Once all of the prep work was done on the right wing I once again asked Daisy, Heather, and David for their help. We had an easier time with this wing, even though space was limited under the staircase and next to the water heater. I was able to align the holes with the drift pins and then replace these one at a time with hardware store bolts. Both wings are on! I can't believe it. In my basement no less! Woohoo! One thing that I will have to do soon is make new, shorter sawhorses. Otherwise I won't be able to mount and test the ailerons since the right wing is too close to the staircase.
Right wing mated
Right wing mated
Both wings are on!
Both wings are on!
Both wings installed
