Dan's Web Site
Date:  11-4-2003
Number of Hours:  3.00
Brief Description:  Aileron Pushrods
Today I finished the short aileron pushrods. I inserted the rod end bearings, drilled them to the pushrods and then riveted them in place. Then I measured and cut out the long aileron pushrods. Since the short pushrods are powder coated I thought this might be a good time to try a new paint. I decided to prime the long pushrods with Rustoleum primer. I will topcoat these later with Rustoleum white enamel to match the powdercoat on the short pushrods. I want to test how well the Rustoleum paint sprays on as well as how durable it is.
Rivet rod end bearings to short aileron pushrods
Measure and cut long aileron pushrods
Prime long aileron pushrods
