Dan's Web Site
Date:  9-15-2002
Number of Hours:  1.00
Brief Description:  Right Tie Down Assembly Drilled to Spar
I clamped the right tie down to the right spar using the one measured hole and drilled hole. Then all of the other 7 holes were back-drilled using the holes in the spar as the guide. The left tie down spacers were then clamped and drilled to the left spar.
Right tie down clecoed to right spar
Right tie down and spacers drilled and clecoed in place
Left tie down spacers drilled and clecoed
