Brief Description: Micro Bottom Rudder Tip & Vert Stab Tip
Today I sanded the bottom rudder tip as well as the vertical stabilizer tip, cleaned everything with Acetone, and then used mixed up another batch of micro. The micro was used to fill in all of the small gaps around the bottom rudder tip as well as the large gap around the rudder horn. I'll sand this tomorrow and add one layer of fiberglass around the entire joint to strengthen the bond.I also added another layer of micro on the vertical stabilzer tip to build it up a little more in order for it to better match the contour of the top rudder tip.
Bottom rudder tip sanded, cleaned, and microed
Vertical stabilizer tip sanded, cleaned and microed
