Brief Description: Rivet Airseal Fabric to Right Aft Baffle
After deburring the baffle, I clecoed the airseal strip to the baffle and began pop-riveting. I used small #4 washers on the tails of each of the pop rivets used to rivet the airseal fabric to the baffles to prevent the pulled rivets from locally denting the thin baffles. Some of these large-headed pop rivets lost their mandrels as they were being set/pulled so there is a hole that now needs to be filled. I'm not quite sure how I'm going to do that yet. I left the center rivet hole open for now. I'll use a screw and metal stop-nut on all of the baffle overlaps so I can still remove the 4 corner baffle sections if I need to without cutting the airseal material.
