Brief Description: Fab/Match Drill Center Sub Panel Parts
The next thing I worked on was the center sub panel. I trimmed the F697 hat and F643 center rib according to the plans and drilled and clecoed these to the center section of the sub panel. I also fabricated and match drilled the F768C seal support angle to the top of the sub panel. The final task for the day was to fabricate the F644 outboard ribs.
Hat, center rib, seal support trimmed&drilled to center sub panel
