Dan's Web Site
Date:  9-12-2005
Number of Hours:  4.00
Brief Description:  Fabricate F703B/C Panel Support Angles
The F703B and C panel support angles required several relief notches to be cut to allow the stiff angle to bend around the contour of the panel. I marked the notches, drilled the appropriately radiused holes in the vertex, then used the bandsaw to cut actually cut the notches. This wasn't too difficult. The hard part was deburring all of the edges around the remaining tabs. Very tedious. Once everything was deburred, I bent the angle to match the upper edge of the panel and then match drilled the angles to the panel. I'm glad that's done!
F703B and F703C panel support angles fabricated/drilled to panel
