Brief Description: Elevator Trim: Drill Servo to Brackets
The last thing I worked on today was the elevator trim. I was able to clamp the servo to the two brackets that hold it to the access plate and then drill the servo to the brackets and then the brackets to the access plate.
Elevator trim servo drilled to access plate and brackets
