Brief Description: Notch Tunnel Cover; Drill Safe Tie Hole
The next thing I worked on was notching the forward left corner of the tunnel cover. This was necessary to fit around the center support block for the flap actuator arm. The final thing I did today was drill a small hole in the lip of the flap motor arm for safety wire.
Tunnel cover notched for flap center support block
