Dan's Web Site
Date:  12-31-2007
Number of Hours:  1.50
Brief Description:  Install New Nose Gear Leg in Engine Mount
I sprayed some more WD-40 onto the new gear leg and into the engine mount tube and was able to easily slide the new leg into position. Next I installed the AN5 bolt from underneath using the access hole in the firewall. I installed the washer and all metal lock nut and torqued it to 90 in-lbs. I then used some blue torque seal on the nut for easy inspection from time to time.
New nose gear leg installed in engine mount
AN5 bolt torqued and torque sealed
