Brief Description: Test and Reverse Aileron Trim Wiring
Next I decided to test out the aileron trim wiring by powering things up and hitting the left and right switches on both the pilot and then the co-pilot sticks. Everything was working opposite of what it should so I had to reverse the two white wires going to the servo. Once that was done everything was perfect!
I couldn't test the elevator trim relay and indicator since I don't have the servo hooked up yet on the elevator trim tab.
