Brief Description: Run Strobe Wires from Power Supply Out to Wings
Since I was already working on the wires for the Whelen power supply for the tail strobe I decided to run the strobe wires for the wings as well. I wish I had planned this out better when I was working on the wings and fuselage. I would have routed the wires towards the front of the wing rather than through the aft tooling holes in the wing ribs. As it stands now, the wires will route from the front of the wing tips to the aft part of the tips, down the wing just in front of the rear spar, then zig forward again to enter the fuselage just under the large lightening hole for the aileron push tubes, then down the center of the fuselage under the left seat and baggage floor to the power supply mounted on the left side skin. Lots of unnecessary zigs but difficult to change at this point. Very poor planning on my part but as I mentioned in many other log entries I should have been thinking about wire routing from the start of the project and throughout the building process rather than just now.
18awg shielded 3-conductor wire for right wing strobe
18awg shielded 3-conductor wire for left wing strobe
Routing of wires for the wing stobes - through conduit one bay left of the tunnel
