Brief Description: Rivet Brackets for Headset Jacks to Fuselage
I was able to use the pneumatic squeezer to set 4 of the 5 rivets on each headset bracket. I ended up using a Cherry Max rivet for the last hole since I couldn't fit the squeezer close enough to the bulkhead without scratching / damaging something.
