Brief Description: Wire #2/4 EGT and CHT Probes to Dynon EMS
Each CHT and EGT probe has two wires with fast-on terminals. Once I had all of the wires from the probes bundled together and routed where I wanted them I cut the each lead from the Dynon EMS to the appropriate length, crimped fast-on terminals to each wire, and then connected them to the probe terminals and heat shrinked them together. The left side is done - Cylinders 2 and 4.
Cyl #2 and #4 EGT and CHT wires connected to Dynon EMS wires and bundled together
Cyl #2/4 EGT & CHT wires connected to Dynon EMS wires and bundled together along with carb temp wires
Full view of left side EMS harness running from under the cyl's, up the engine mount & to the firewall
