Dan's Web Site
Date:  5-28-2007
Number of Hours:  0.50
Brief Description:  Connect Left P-Lead / Ground to Left Mag
Next I used the heat gun to attach another solder sleeve / pigtail to the shield on the mag end of the left P-lead, crimped ring terminal's to the ground wire and P-lead primary wire, and then connected these to the left mag.
P-lead for left mag with solder sleeve and ring terminals attached
P-lead and ground (shield) attached to left mag
