Dan's Web Site
Date: 8-26-2006
Number of Hours: 1.00
Brief Description: Remove Elevators, Sand Flanges, Clean, Dimple
Next I removed the elevators, sanded the inside flanges with 40 grit, cleaned with acetone and dimpled. There wasn't enough clearance to use the squeezer on the aft 2 holes on each side, nor could I fit a nail in each hole to use the pop rivet dimple dies. What I ended up doing for these is cutting off a nail about 1/32" longer than the depth of the two pop-rivet dimple dies mated together. I used the short nail to center the dies in each hole and then just squeezed the dies together over the nail using some vice grips. This worked out very well.
Elevators removed, inside flanges sanded, cleaned, and dimpled
#30 Dimple dies, a cut-off nail for centering, and a pair of vice grips
