Brief Description: Install Gascolator and VA-129 Fuel Line
Next I installed Van's gascolator on the firewall. I used high-temp RTV to seal the opening through the firewall. I also installed the firesleeved VA-129 fuel line onto the gascolator that will eventually run to the engine mounted fuel pump. I also fabricated and installed the 3/8" fuel line that runs between the electric fuel pump and the gascolator.
