Brief Description: Create Shims For Top Flange of Wing Tip Rib
The top surface of the fiberglass wing tip towards the back where the rib gets installed is about 1/4" lower than the top surface of the aileron. The bottom surfaces are flush but not the top. I decided to make some tapered shims for the top flange of the wing tip rib to raise the fiberglass to be flush with the top skin of the aileron.
Shims for the top of the wing tip rib to raise the fiberglass surface to match the top of the aileron
Shims drilled, deburred, tapered, and clecoed to top flange of right wing tip rib
