Dan's Web Site
Date:  3-7-2012
Number of Hours:  0.25
Brief Description:  Wing Tip Cosmetic Problems
There are some cosmetic things that still need to be done on the aft area of the wing tip to align perfectly with the aileron. I need to trim the trailing edge about 1/4" inch since the fiberglass sticks out past the end of the aileron. I also either need to add some shims to the top flange of the rib to raise the top surface of the fiberglass a bit to be flush with the top surface of the aileron, or I need to build up this area with some filler. I'll probably try the shims first to see that does the trick rather than adding more weight for the filler.
Right wing tip - bottom surfaces are flush but the top surfaces are not
Trailing edge still needs to be trimmed
I either need to put some shims on the top flange of the rib to raise this area or use som filler here
